Wheel order for brake fluid rep?
Received 6,310 Likes
Norri is spot on like usual.
When removing the old fluid, just be careful not to completely drain the reservoir or you end up pushing air through the system. So take most of it out with a fluid transfer device or turkey baster, then add new fluid to the little bit of old fluid. Frequently check the level in the reservoir as you go to make sure it is topped up while bleeding. Once you get clear clean fluid and no bubbles at the first wheel, move to the second and so on.
hunter34
19
09-14-2022 11:09 PM
Holden
09-05-2015 03:29 AM
