Wheels
Old 02-14-2007, 12:26 AM
Default RE: Wheels
18" is probaly the highest you can go(safely). There's a few around here that have gone bigger but with some issues. Do a search and you'll see...
Old 02-14-2007, 12:02 PM
RudyF6's Avatar
Default RE: Wheels
18x7.5 w/40mm backspacing on stock (not sport)suspension. Perfect stance and no rubbing so far.
[IMG]local://upfiles/857/895A1811361A433A8B8F548A9A590F0D.jpg[/IMG]
Old 02-14-2007, 01:32 PM
nineball's Avatar
Default RE: Wheels
18" here as well with no problems
Old 02-14-2007, 04:49 PM
RudyF6's Avatar
Default RE: Wheels
BTW, anybody know the backspacing of an O.E. Jag. 18x7.5" rim? Mine at 40mm are about as far outboard as they could get without rubbing.
Old 02-14-2007, 08:10 PM
racerx82's Avatar
Default RE: Wheels
I got monster mudders 56's on mine with no problems..... I'm able to take mine four wheelin and all! yeah haw!!
Old 02-14-2007, 08:33 PM
gotti15's Avatar
Default RE: Wheels
I have 19x8 Armano Vega wheels w/ 215/35/19 tires, so no rubbing.I'm planning on putting some 225/35/19 tires soon; I think the wider tire will improve the handling. The 215's are too narrow. I also put hubcentric rings on; so the ride is pretty close to stock.
[IMG]local://upfiles/1079/7DEF2BF01154442F8015A054D0F2FD05.jpg[/IMG]
[IMG]local://upfiles/1079/F1ADC3319E974EA0B65A854D9090B608.jpg[/IMG]
Old 02-14-2007, 11:13 PM
racerx82's Avatar
Default RE: Wheels
You have the stock ride height, most of us here had their ride lowered so 18's is the biggest we can go wiithout damaging something
Old 02-15-2007, 10:33 AM
RudyF6's Avatar
Default RE: Wheels
ORIGINAL: racerx82
Kool dude! Didja put a lift kit on or jist cut the fenders out?
Psst - Racer...... We better tone it down or some of our Brit pals here might think we're the rednecks from the Top Gear clip!
Old 02-15-2007, 10:58 AM
Received 9,011 Likes on 4,114 Posts
Default RE: Wheels
lol......tell you what Rudy, those rednecks.........jeez!!!
Did you see it?
Tell you what though, certain parts of Glasgow, just as bad, they don't take any ****.........you drive thru less than 30 and they take your rims..lol
Jim C
Old 02-16-2007, 09:34 PM
aquill1's Avatar
Default RE: Wheels
Hey there Gotti15 is there any way you could take some more pics of the car with rims-ie closeups of rims and fenders and front and rear shot of the side for me? Also any way you could load some bigger ones or do you have a web album on-line somewhere?
Old 02-19-2007, 01:29 PM
gotti15's Avatar
Default RE: Wheels
Aquill1, I dont have an online album; but check out my Cardomain.com site:
http://www.cardomain.com/ride/1701401
I took some new pics over the weekend...finally had some sunny weather in No. Cali, so I was able to wash the X.
Congrats BTW!
Old 02-20-2007, 05:59 PM
ruslan35's Avatar
Default RE: Wheels
Just wanted to let you know before you put 225 tires on there... i had 225s on my 02 x-type 2.5 and it was rubbing preatty bad....
Old 02-20-2007, 06:29 PM
gotti15's Avatar
Default RE: Wheels
Really?I'll keep that in mind. I'll talk to my local tire shop (Big-O Tires) and see what they suggest. I think the 225's will fill out my wheel well & wheel width perfectly.
The rep at Tirerack.com suggested 225's, and told me that my current set-up 215/35/19 was incorrect for the X-Type due to the load rating of 85; but it was my understanding that the load rating of 85 has a max weight of 1135 per tire, so its suffcient for the approx. 3500lbs of the X-Type. Am I wrong?
Old 02-21-2007, 06:59 AM
04Xtype's Avatar
Default RE: Wheels
ruslans rite about the 225, i have 18x8.5 with 225/40 /18, with the stock suspension it only rubs when u have people in the back and going over bumps of taking fast corners. As u are nt going to lower the cr, u shud be fine. I went and lowered it, and had the fenders shaved. It stil rubs ike crazy, so now i consider my car a 2 seater. no one sits in the back, and i take bumps at10 mph below the speed limit. Its worth it for the look though. Hope ures turn out well, and im sure the wider tire will look great, from the bck and the side, so isa win win sitution
Old 02-21-2007, 01:20 PM
nineball's Avatar
Default RE: Wheels
strange.. i have the same size on my 04 (225/40/18) and i have not had it rub once on me, even with 4 people in the car.
Old 02-21-2007, 04:17 PM
RudyF6's Avatar
Default RE: Wheels
Nineball, what's your rim width and offset?
Old 02-21-2007, 10:00 PM
nineball's Avatar
Default RE: Wheels
i am pretty sure these are the right specs, but i may be wrong.
Size
18x7.5"
Offset
42 mm
Bolt Pattern
5-108m
Diameter
Rim Size
7.5
Hub Bore
Old 02-22-2007, 11:01 AM
RudyF6's Avatar
Default RE: Wheels
Thanks Nineball, I haven't had anyone in the back seatwith the new rims, but my offset is 40mm, same 18x7.5 sizeso itshould be fine!
Old 02-22-2007, 09:04 PM
04Xtype's Avatar
Default RE: Wheels
My wheels are a little wider so that cud be it, and rite now i cant have peoplein the backcos ive lowered the car, before the lowering it rarely rubbed, just some big bumps + people.
Quick Reply: Wheels
