When Turning Right in at normal speed or backing up it makes a studder noise
Old 05-04-2018, 06:33 AM
joshuaaa1209's Avatar
Default When Turning Right in at normal speed or backing up it makes a studder noise
So when I drive my Jaguar it makes a studdering noise when I back up and turns the wheel to the right. It also happens when driving and it's cold when it's warm it hardly does it.but still will. I've replaced that sides swaybar end link about to do the ball joints. Not sure whats causing the noise can't figure it out.
Front right suspension
Old 05-04-2018, 07:57 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
You need to put it on a lift and with the transmission in neutral check for excess play or binding in the axle CV joint.
joshuaaa1209 (05-04-2018)
Old 05-04-2018, 08:43 AM
I'll get it up on my lift this weekend, I honestly didn't even think to check the CV Axels. Probably check them when I go to do the Ball joints. Thanks for the suggestion, I'll get back to the thread and let you know if that's what it was.
JigJag
01-03-2021 10:22 AM
Gibbo205
02-03-2019 11:40 AM
muttony
05-02-2018 07:37 AM
JagGirl1954
XE ( X760 )
01-12-2016 09:18 PM
tberg
09-08-2014 03:24 PM
Quick Reply: When Turning Right in at normal speed or backing up it makes a studder noise
