Where is the clutch master cylinder?
My 2003 2.5L 5 speed, 106K miles, has the dreaded clutch pedal problem, where the pedal sticks down. I pull it back up manually from time to time. Today, I noticed a significant brake fluid leak where I park, and suspect it's from the clutch master cylinder.
So, I jacked up the car and went in search of the clutch master cylinder. I don't see it. I can easily see the bottom of the brake master cylinder and it's not leaking.
Any thoughts?
Thanks!!!
Any thoughts?
Thanks!!!
