Where to find codes for diagnostic/ engineering mode
If you want a definite summary of all the codes then I suggest installing JTIS which can be found as a sticky in the x type forum. Once started go to "3. Powertrain" > "Electronic Engine Controls" > "Diagnosis and Testing" > "Electronic Engine Controls".
This gives you all the codes you could encounter and rectification actions.
Received 3,887 Likes
foxbottom, I have a listing of all the meanings of the codes when you put the instrument cluster into diagnostic mode and how to take the values that it gives you and convert them to useful numbers. PM me your e-mail address and I will send you the word document. You will also get some other useful information that is part of that file too that you might find of interest.
foxbottom (09-10-2016)
JagV8, where the instrument cluster is far better than any code reader out there is that once you get into the Engineering Test Mode, you can see what the sender is giving to the computer as an input. The code reader will only give you the final output. With the input values, you can determine if you have a sender issue, no tools are needed to figure that out.
Yes, I will agree that looking at the error codes that are pulled from the instrument cluster will send you on a wild goose chase pretty much every time. that is when the code reader is the way to go.
Rozza
09-09-2016 02:22 AM
