Where to purchase Air Control Valve O-Rings
My car is throwing intermittent P0174 codes so I searched here and saw a few threads on this error. Well I can confirm that the o-rings on my air control valve (not sure if that is the right technical term) are leaking. I get a pronounced whistle coming out of the top one when cold. It does go away once the car warms up but it has thrown the code by then.
Are these o-rings dealer only? Are these standard o-rings that I can find at a hardware store?
I went to a few local auto parts stores and they looked at me like I am nuts when I explain what I need.
I swiped, err borrowed, a picture from another thread to show the parts in question. Here is the thread I was reviewing.https://www.jaguarforums.com/m_34490/tm.htm
[IMG]local://upfiles/3130/7C4803A32FAE4141BB9EDBECA87F6153.jpg[/IMG]
Guest
Posts: n/a
RE: Where to purchase Air Control Valve O-Rings
in Jag-speak, they are called IMT seals ( imtake manifold tuning ) but they are pretty much basic o-rings. You can remove one (2 screws) and try to match it up at a place that has a selection of orings. Or get them at the dealer.
The other possibility is the check valve on the brake booster vacuum line. It is more likely to be the thing that is whilsting. it is easy to test for this, just cover up the check valve with your hand when it is whistling and it should block the sound.
keep us posted.
keep us posted.
I bought mine from the dealer. They were in stock and cost $2.70 Canadian each. Why bother to shop around?
Also if you take measurements from the existing they may be too small. We are told the latest Jag rings are slightly larger than original to fix this problem.
Brian
Brian
OK I took off the top Intake Manifold Tuning valve to get at the o-ring (thankfully this is the one whistling). What I noticed on mine is the lower one will not come off as the valve cover is in the way. I tried twisting quite a few different ways but no luck. This may be the excuse I need to pull the intake. If I decide to do this then I will install new plugs and I may even go the extrude hone route in an effort to extract a few more MPG out of the car. Wait I mean HP.
Has anyone been able to remove the lower Intake Tuning Valve with the intake on? If so I may try a little more to wiggle it around and see if I get lucky, but I doubt it.
I checked the brake and PCV lines and all look good. I noticed the spot where the brake booster connects to the intake seemed loose but there was no vacuum leak there. I am going to sift through the manual I have to see how this is connected. I hate pulling and tugging on these little plastic pieces as they are so brittle. Stay tuned more to come.
no dont do that!!!!!!!
tooooooo much work!
Just cut the old one of with a razor blade(if it isnt already split) and slip the new one on from the back. Its gonna be a little stretch to get the new one on past the fat part... but believe me you'll be happy you did. It shouldn't break the o ring either.. just keep both sides kind of even when you stretch it over and do one side at a time to limit stretch.
tooooooo much work!
