Whine
Guest
Posts: n/a
Whine
Back in December, there was a great post showing how to fix the Jaguar "whine" by greasing the drive shaft at the TC and Rear Diff. However, I have a plastic cap that covers the entry point to grease, has anyone else had to remove these? I do not want to remove and break then have more issues. Thanks.
RE: Whine
Bito:
are you referring to greasing the prop-shaft's center bearing? THAT is the one that circulates most frequently, and Dennis has created an awesome FAQ for it in the FAQ section.
I think that the general consensus though, is that this doesn't help much, if at all, as the whine stems from the rubber surrounding the bearing, rather than the bearing failing.
IIUC
IIUC
BrentGardner
28
04-26-2024 03:08 AM
