whining noise
Ok so for the last two months my xtype has been making a whinning noise from the right wheel well when turned to the right. It's not as bad as it was but I can't stand it. I figured it was a bad bearing but the front end felt tight and I even had a mechanic look at it he said its not the bearing. It's only when I go to the right and it doesn't come from the steering wheel but instead the right wheel. It doesn't happen when I turn to the left. I also thought it could be power steering but left that idea because it only happens on right turns Any ideas? Anyone had this issue.
Just bought myself an x type and having the exact issue, it's driving me nuts. Just had a wheel bearing done thinking it would solve the problem, but sadly not. Did you ever find out what it was? If so please help.
Many thanks
baskervillema
10-01-2015 06:43 PM
