WHINING NOISES - ENGINE / TRANSMISSION?
#121
#122
RE: WHINING NOISES - ENGINE / TRANSMISSION?
Hey dunhill I think I have the noise you are speaking of that isnt' the tires and not the rattle but the other one. It's not annoying right? Because originally when I first got the car I thought it was the engine but when you put it in neutral it doesn't make it-right? If so mine has that noise as well, I assumed it was part of the awd system of the car. Mine isn't loud or annoying or anything though...
#123
Received 9,010 Likes
#125
#126
#127
ORIGINAL: racerx82
Ok, found 2 TSB's:
1. Drive shaft vibration-says to check for green line on rear diff flange (if not aligned, you have a problem)
2. Sound transfer from transmission.-- (install deadining liner)
Ok, found 2 TSB's:
JC
#130
#132
#133
The noise is intermittent and not that loud. It goes away in neutral. It is not engine related at all. In drive, it almost sounds like a whininig noise at lower speeds and a rattle. Now, it doesn't do it all the time....I will have the dealer look at it.
#134
Well Dunhill, I wish you better luck than me.
I took mine to the dealer and they had it o/nite as the prob was intermittent. Went back and they said that they couldn't fault the car.......lol.........for diagnostic check and "loan car" cost me £103.......and still no further forward, so beware!
Jim C
#136
#138
[/align][/align]If you own an XJ or XK, you should get your vehicle serviced every 10 000 miles or every 12 months, whichever is the sooner. If you own a petrol S-TYPE or X-TYPE, you should get your vehicle serviced every 10 000 miles or every 12 months, whichever is the sooner.If you own a diesel S-TYPE, you should get your vehicle serviced every 15 000 miles or every 12 months, whichever is the sooner. If you own a diesel X-TYPE, you should get your vehicle serviced every 12 500 miles or every 12 months, whichever is the sooner.[/align][/align]Jim C
[/align]
[/align]
#140
Its gonna be tough for me to keep track of where I am....lol
The car's nearly 4 and a half years old.......(looks about maybe 2 years old though - good condition) and only has 18.5k on the clock. When I bought it about 5 months ago it had just been serviced, so I guess it'll be getting done again in about 6-7 months time.
JC
