Who sales the TC Case fluid change kit on here?
I am wanting to change my TC case fluid and I was told that someone on here sells the kit with all the fittings and everything you need to change it. It would make life easier if I could just buy this kit rather then go and piece one together. So if anyone knows who sales it please tell me!
Thanks!
Tony
Thanks!
Tony
I'd suggest that instead of worrying about a fluid changing kit that you simply go with the "manual" approach that has been described elsewhere on this list.
Long story short: 1) remove T-Case plug and let fluid drain out; 2) raise car and
put blocks under the driver's side wheels and then lower car so that it is raised on one side; 3) fill T-Case until fluid starts to run out of drain hole; 4) replace drain plug; 5) raise car and remove blocks; 6) done...
Does anyone remember how high to raise the car on the driver's side?
Jaguar: Grace, Pace, and Space - Sir William Lyons
The recommendation made was 24" from the ground to the bottom edge of the side skirt. I get mine up to about 19" on the driver side for the fill, which is a lot of tilt to me and seems to work fine.
Wolfy
05-28-2024 08:06 AM
Wes Steenrod
09-06-2015 06:52 PM
