Will 3.0 replace 2.5?
I have not done the swap. However, there is someone who has done it on these forums. Hopefully he pokes his head into this thread. The Lincoln LS engine is the 3.0 engine in a different configuration. As the Lincoln engine is mounted fore-aft in a conventional rear wheel drive car.
If you choose a Jag 3.0, it's very much the same engine (with more power)
I recall reading about another guy doing a swap and it, for the most part, worked out very well. Just a couple of minor glitches that may not have had anything to do with the engine swap.
https://www.jaguarforums.com/forum/x...ype-jag-34228/
car5car (02-11-2014)
