Window switch help please
What’s up guys. My drivers main window switch is acting up. Only the drivers window switch. Feels like it’s loose or disconnected possibly. Window still goes up and down. However I don’t want the window to get stuck in the open position. Is there any fix for just one switch in the main window control switch on the drivers door ? Or do I need an entire new switch ? Thx.
Received 3,898 Likes
Ah, you mean the actual "lever" dedicated for the driver's window in that switch, which contains 4 window levers!? That would probably mean that a little "nibble", which holds the lever in place, has broken off. Well there might be a way to fix that, but I am not sure how long a fix of broken plastic would last, plus, you have to be very careful not to loose any part when opening that switch. You would most probably be able to create one working switch if you have 2 broken switches (as all you need is a new lever for the donor switch). But as you are unlikely to find such a donor switch, your best bet is indeed to buy a new switch. 1X43-14A132-BE E-Bay Australia shows one for AUD$80. But this would be for the RHD version for the X-Type and I am not sure, if it is identical to the LHD, which you have.
Yorta2 (06-25-2023)
Yes, I remember now (as I think this window switch was one of the ones, which were in my electric-design responsibility): The reason as to why it is the same for LHD and RHD is, that that, what makes it different (the outer bezel), is an integrated part of the door trim.
And I think internally it might be the same as the Mondeo switch, but externally the Jaguar Stylists gave it a new appearance.
This is the Mondeo window switch (just as comparison):
https://i.ebayimg.com/images/g/hRIAA...1vo/s-l500.jpg
When that topic of folding mirrors came up here, I did a little research. While I was relatively sure that I do not have folding mirrors, I wanted to know for sure (just in case I have them and there is a trick to activate them, which I don't know yet). I think folding mirrors are relatively rare on X-Type. But if you have them, it looks like they should fold, if you double-lock your car (i.e. press the lock button on the remote twice). That is one way the test and the other more obvious way to look at your switch (see Mark's picture above).
Ah, you mean the actual "lever" dedicated for the driver's window in that switch, which contains 4 window levers!? That would probably mean that a little "nibble", which holds the lever in place, has broken off. Well there might be a way to fix that, but I am not sure how long a fix of broken plastic would last, plus, you have to be very careful not to loose any part when opening that switch. You would most probably be able to create one working switch if you have 2 broken switches (as all you need is a new lever for the donor switch). But as you are unlikely to find such a donor switch decorative concrete Utah, your best bet is indeed to buy a new switch. 1X43-14A132-BE E-Bay Australia shows one for AUD$80. But this would be for the RHD version for the X-Type and I am not sure, if it is identical to the LHD, which you have.
I never had a Lexus - and a GS300 is a Lexus. But when I googled what your window-switch looks like...: Very similar.
Thus: Remove the door panel and when removed turn it upside down, look for the inside and there should be roughly 3 little bolts under the window switch screwing the switch-unit to the door panel....
Obviously, before actually switching (=changing) the switches, you could try first to remove the connector from the OE switch, plug it into your new switch and see if it works.
johnpiero
01-24-2010 11:38 PM
