window trim flew off
Received 3,910 Likes
Spooky, your best bet would be a local wrecking yard. Otherwise, you are going to end up buying the whole window trim kit and that is going to be fairly pricy. Jaguar list price is $95 for the left side and $91 for the right side. This is going to be the rubber that goes around the small fixed window that also runs up and over the roll down window. That is one big piece. Through the shop I normally use, the pieces can be had for $81 and $77 respectively, then you need to add on S&H from there.
1964Daimler
09-09-2015 11:28 AM
