Windshield defrost not blowing air on the windshield!
Car is not blowing air on the windshield when the button is pressed. Instead it blows hot air at my feet. It seems like there should be some sort of flap that is suppose to divert the air and its not doing it. All other vents work fine except the defrost. Please tell me this is simple to fix.
With the AC running, you could try a recalibration of the flap stepper motors as described by Jaguar as follows;
• Select full cooling (Lo)
• Select full heating (Hi)
• Back to full cooling
• Select face followed by floor
• Then select face again
• Finally select defrostIf there is any doubt, then a battery reset should be completed; wait two minutes before reconnection.
bracester (03-08-2013)
From your description, it sounds as though the stepper motor for the defrost flap is disconnected or has a faulty connection or is defective. It could also be a broken drive connector between the motor and the flap or even that the flap is seized but that's least likely.
All the stepper motors are powered directly from the Climate Control Module, so if the others are operating, there is not a fuse/supply problem.
The triangular layout of the three flap stepper motors can be seen on the righthand end of the central airbox. The defrost motor is the top one nearest the engine. You might need to remove the air trunking that gets in the way, but that's self evident , and the motor itself is held by three screws. Once it's out you should be able to work out what the problem is!!
When I looked under there I saw three motors in a triangle formation, and by your description the top motor is the potential culprit. Before I fiddle with this could you just verify what I am looking at is what I'm suppose to be looking at?
Thanks!
Sorry to be so long in responding - I've been on vacation for the last week.
HarryC, it may be that you've just pushed a bit too hard, flexed the flap and allowed the the shaft to fall inside. Have you tried to 'fish' for it and get it back - better than trying to replace the unit - that's a big job!
LarMan, the bottom stepper motor is for the blend door - that controls the temperature of the air by allowing the right amounts of cold and hot air to get what's wanted. The third motor regulates the distribution between the upper panel and the floor.
The recirc motor is not a stepper motor - it's an ordinary electric motor and is situated on the other side of the central unit to the stepper motors. It has been quite common for it to disconnect mechanically from the flap spindle and requires to be glued back in.
How to diagnose:
1.Look under dashboard on both sides toward radio, find motors.(usually 3). Touch one and switch vent modes. You should feel it working.
2.Check climate control codes(you need expensive scanner)
Sometimes blend doors break.
And once again Car5 announces faulty info. Here's a suggestion Car5. Search this forum, look at blend door, actually called "stepper motors" fixes and then see how "easy" it is. Hells bells shut up if you don't ACTUALLY KNOW, your suppositions are more than a nuisance!! It misleads current and future members looking for help.
Snapbacks2002 (08-29-2023)
This is an old post so I hope you can help, is it same for S type? Defrost not working, I hear the motors creaking! Doesn’t look that easy to get at, had dash all torn apart but looks like it’s on drivers side? LHD
thanks for the reply, I have seen that video.
that door is the easiest bro get to but is for air in or to recycle air. Looking for the defrost and how to get at it. I do appreciate the reply!
@blatzhtr https://m.youtube.com/watch?v=JY2VkQydDf8 Also posting in the S type forum might be more beneficial
@blatzhtr step by step repair instructions for an S type https://www.brakeandfrontend.com/tec...se-on-jaguars/
thanks again, I appreciate the reply
