Windshield replacement: normal vs heated
the current draw of the front windshield heater is very high. It will be very hard on the alternator to leave it on for extended periods. Factory installation has a short timer, just enough to melt thin ice. I suspect they did that for a reason.
Please let us know when you go alternator shopping....
Hey Thermo,
Do you have more information on wiring the front windscreen into the rear defrost button. I have a 2002 X-type and I had a heated windscreen installed where there wasn't one before I was going to go out and get the relays this week but didn't realize I don't have a switch for it. Any help would be GREATLY APPRECIATED!!!
read my previous posts. i wired the control of the relay from the rear defog relay.
but in the end I wanted to be able to operate them separately. so, i wired directly from the battery and put a switch on the way. I was planning to use a timer but got lazy. i forgot it on 2 times and you know what happened....
I try not to use both rear and front defog at the same time. Battery and alternator ok until now...well I just replaced battery after 6y3m. maybe the 2 times when the battery was fully consumed actually helped the long life (I usually get 4years on a car battery) even if the literature says it is not recommended.
42Ajd
12-30-2015 09:45 AM
CaneCounsel007
11-13-2015 09:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
