Wiper Problem
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Hello all. I have a 2005 X Type VDP. I'm hoping that someone can help me out with a windscreen wiper problem.
My wipers won't turn off regardless of the position of the wiper switch. It started out with my wipers coming on for 1 to 3 swipes randomly, then going back to park. One day, they came on and haven't gone off since. The only way I can turn them off is to pull the fuse. It's finally starting to rain in Northern California, so I guess I'd better make fixing this a priority
I believe that there are about 4 places where the cause can be. The switch/stalk, relay in the steering column, wiper motor, and wires near the brake pedal shorting.
Which area is most likely the culprit for rogue wipers not turning off? I don't have the money to guess and replace or to take a mechanic, nor the knowledge/tools to diagnose. So any help would be greatly appreciated.
smillerncl (11-08-2015)
Hi Vern, The relay for #6 was absent. So I set out to find the relay for #4 (wiper motor relay). Long story very short, even the local Jag dealership doesn't show a relay for the wiper motor. I pulled the relay and read the Jag number to them, it's listed as, or is the same part as, the turn signal relay. Looking on Napa's site, their part for a turn signal relay looks exactly the same as what I pulled out, including a notch in one top corner.
Napa has to order it from Seattle as the Sacramento warehouse doesn't have it in stock.
Jag wanted $45, Napa has it for $8.95.
Napa Part Number: ECH AR6550 Listed as a turn signal indicator.
Going to see if I can get my current one tested and go from there.
smillerncl (11-11-2015)
Did that Napa part work for you? Having the same issue and need to replace relay (I think).
Also -- while I did have a relay in the R6 slot, it wouldn't fit in the R4 position. The passenger side blade is bigger on 6 (windshield heater) than on 4 (wiper motor).
I wonder if they changed it between '02 and '05 on the X-Types.
In any case, I just went down to the Ford dealer and they'll have it here tomorrow. For $6 it's worth a shot.
Last edited by FrankBama; 03-07-2017 at 02:11 PM. Reason: added add'l info on blade size and Ford order
FrankBama (03-07-2017)
FS[SouthEast]: 2005 XJR Part out
motofreak72
20
02-08-2016 05:29 PM
