Wipers that don’t wipe when washer on
I have seen here before (can’t find it now) how some people said that there wipers do not engage when the washer fluid is turned on. Well this might help: I was driving the other day and the amber warning light cam on and read “low washer fluid” when I used the washers with the low fluid light on I noticed that the wipers did not wipe. I had to manually turn them on. I think maybe there is a switch that controls the auto wiper when the washer fluid is sprayed. I filled the washer tank back up and they worked no problem. For those that have this problem try running the tank dry then refilling. Hope this tid bit of information will help you fix or it least find out what is wrong with your wipers.
Received 9,010 Likes
![Name: T15ESSJAG5.jpg
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/193602d1501332114-wipers-don%E2%80%99t-wipe-when-washer-t15essjag5.jpg)
![Name: X6JYMSAAB5.jpg
Size: 6.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/193603d1501332114-wipers-don%E2%80%99t-wipe-when-washer-x6jymsaab5.jpg)
![Name: AudiX6JYM-2.jpg
Size: 6.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/193604d1501332114-wipers-don%E2%80%99t-wipe-when-washer-audix6jym-2.jpg)
Nice piece of info there jvegas
I do know what you mean though Bo, without having a go at anyone who doesn't ( not me!!)
I usually like to at least browse thru the owners manual if only to see what special toys or gimmicks there are and there's usually a few. You'd be surprised at how many people have cars and don't know that they have global open or global close or evern both?
Its always a great idea for sure.
Jim
Guest
Posts: n/a
ORIGINAL: jvegas
what is global open? or close?
I think all x's have this feature. I dont think there is Global Open on any cars. - AGAIN all this is in the owner's handbook. So shame on you all for usinga message board to learn things that are already at your fingertips.
But here is a helpful hint that is not in the handbook.
There is a dealer activated feature called remote global close where you can close the windows and roof by pressing and holding the lock button on the remote control (key fob)
Some dealers will activate it for free, some will charge you outrageous amounts of money ($100-$150) and others may even tell you it is not possible.
Good luck! hope you dealer is the free one.
Global open is on all 2003 and newer S-Types, 2004 and newer XJ and I believe 1997 onward XK. They can all be used via remote or lock button in vehicle. Global close is available on all Jaguars via key. Incidentally, a little known fact. Any jaguar key can be used to lock and global close any other Jaguar.
davidboger
10-01-2015 10:13 AM
