Wipers don't work on intermittent setting - FIXED
Guest
Posts: n/a
Hi,
Just acquired a 2004 X-Type SE 2.0D Estate - everything works OK so far except the wiperswhich don't work on theINTERMITTENT setting and, I assume as a consequence, the AUTO setting. Everything else to do with the wipers, front and rear, works fine.
Can anyone suggest a cure?
Thanks.
Thanks.
Guest
Posts: n/a
RE: Wipers don't work on intermittent setting
Hi Jag_Genius. Many thanks for your reply.
The wipers won't work on intermittent, i.e. lifted one click, regardless of which position the rotating collar is in, including auto.
It's really annoyingbecause, until you haven't got it, you don't realise how useful intermittent wiping is.
Any ideas? Is there a relay that controls the intermittent function perhaps?
Haynes don't seem to do a manual for the X-Type. Do you know of an alternative workshop manual?
I have a similar problem. somebody suggested it may be a parking problem?
Jag_Genius: how do i check to see if its the switch or the GEM computer? is this something a rookie (non mechanic) can check or do you need a computer and or skilled mechanic?
thanks!
thanks!
Guest
Posts: n/a
i took my car in for a thermostat issue.. totally unrelated..... and when i picked it up, intermittant and rain sesnse did not work...
I told them it stopeed workingl... and with a few clicks of the magic "dealer computer" they got them back working again.. been over a year... and still working.
Id say chek dealer first.
lol Bo.
Wiper park and intermittent wipe are two different problems in two different areas. Genius said about the intermittent one.
If your wipers will not park, X-Type parks wipers based on a resistance value. If they are not parking normally, ie in middle of windshield, you probably need a wiper motor.
Guest
Posts: n/a
Update
The problem was eventually diagnosed as a faulty relay by a local independent Jag specialist http://surreyjag.co.uk/which I canhighly recommend on price and quality of service.
The wipers now work on both intermittent and auto settings.
Thanks for your contributions.
Hey guys I have the same problem. but that indie shop is too far for me since i'm in the US. can anyone kindly guide me to where I can look for this relay??
secondly my washer fluid is squirting out almost nothing as if there is not enough pressure. I do hear the motor running to squirt out the fluid and the tank is full but not enough pressure? any takers on this problem?
thanks!
thanks!
ORIGINAL: hankycbr
thanks!
thanks!
Look at the washer hose under hood leading to the nozzles. Very visible. See if it is broken.
The following 2 users liked this post by FactoryJaguarTech:
jkevinr (01-01-2011),
mountainfish (12-01-2012)
Hello here is a quick update:
I believe I have the same problem as cutlp. I pulled out R1 Relay and put it back in, my intermittent and the quick 1 wipe was working perfectly, but after a few more tries, it stopped. My question is, how do I test a relay if it is bad? I would like to test this relay before buying a new one? can i bring it a to a jag dealer would they test it for me?
secondly, in regards to my wiper fluid, it will squirt out fluid perfectly if my hood is opened up, there is alot of spray. but once I close the hood, there is no spray coming out as if there is no power, only drips. I checked the visible hoses and they look fine? any other ideas?
thanks in advance, this site has been very helpful in maintaining my cat!
Guest
Posts: n/a
hankycbr,
If I were you I would just swap the suspect relay with a new one. Mine only cost £4.00 including taxes. The UK part numberwas JC2C34433 and I believe it was R4.
The following site provides some useful information:
http://www.jaguarguides.com/Electric...calGuides.aspx
ORIGINAL: hankycbr
If the spray works with the hood open, the problem is likely not electrical. I would look harder for a leaking hose or cracked fitting.
