Would they fit X-Type
Old 07-15-2015, 10:25 AM
GAV 01's Avatar
Default Would they fit X-Type
Hi guys would these wheels fit my x type I do know there are 5 stud
Thank gav ...
Old 07-15-2015, 05:21 PM
GGG is offline
Received 16,865 Likes on 12,186 Posts
GAV,
I've moved your question from New Member Area - Intro a MUST to X-Type forum. This is the place to post tech questions about your model.
Old 07-15-2015, 05:37 PM
GAV 01's Avatar
Hi ok thank you Graham
Old 07-15-2015, 06:50 PM
Justink201's Avatar
No, you need 5x108 bolt pattern. 5x112 sounds close, but they won't work.
Old 07-15-2015, 06:53 PM
GAV 01's Avatar
Ok thank you Justink201....
Old 07-15-2015, 06:55 PM
GAV 01's Avatar
So as long as they are 5x108 there will fit ?
Old 07-28-2015, 06:38 AM
simo5555's Avatar
As long as the bolt pattern is 5x108, ET value is between 40 and 50 and centre hole is 63,4mm or larger in diameter, they will fit. If you pick a set of wheels with larger center diameter, you will need wheel centering spacers too.
way2far
08-31-2022 09:26 AM
Shawn Svacha
11-04-2019 02:47 PM
Chuck Schexnayder
09-18-2015 03:10 PM
texaspete
09-10-2015 08:34 AM
Whitnessmouse
09-04-2015 11:09 AM
Quick Reply: Would they fit X-Type
