Would a twin exit exhaust fit my X?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I'm after a simple bolt on aftermarket exhaust for my 2002 X-type. Problem is I'm in the UK, I have a 2.0L with a single exit exhaust. I was wondering if I could buy a cat back twin exit (Like the 2.5/3.0) and fit it on my car? Is it just a matter of the extra hanger on the right hand side or is the front pipe upto the cat different? Any help would be much appreciated, Thanks in advance!
Received 3,887 Likes
l17led, the dual exit exhaust should fit on to your car no issue. If I remember the car right, the two headers form a single header just behind the motor (at the firewall) and then are a single pipe all the way back to the rear differential. Just before it crosses up and over, the pipe splits into 2 pipes (for the 2.5/3.0L motors). So, you get the dual exit exhaust and you should be able to fit it in no problems. just make sure to get the 2.5/3.0L rear valance with the dual openings.
aholbro1
08-05-2021 05:02 AM
Dickie_L_J_O
09-13-2015 07:44 AM
