wow...this much play in propshaft????
this morning i went to grease my propshaft bearing at the support.
The propshaft moves up and down, left and right inside the support about 1/4 inch or more in every direction. I assume that this should not be so.
When i push up on the shaft i can see daylight between the bottom of the propshaft bearing, and the propshaft support....thermo...brutal et al is this normal??...i cannot imagine it is.
please advise whether i need just the bearing assembly, or do i need a whole new propshaft?...or do you need more info/pics?
anxiously waiting
anxiously waiting
Is there some kind of rubber donut that goes between the bearing and the bearing support bracket?. I don't think the bearing is the problem....when I push up on the d/s the d/s and bearing move together inside the support bracket making me think that there is some kind of bushing around the bearing that is worn out
Woznaldo
09-26-2015 11:02 AM
