X-400 , 2004 model
Old 12-06-2017, 12:00 PM
Rais Mtukufu Gim's Avatar
Default X-400 , 2004 model
am interested to understand the p0420, among the other codes
Old 12-06-2017, 12:05 PM
My mech says we should chnge the catalytic converter is this true?
Old 12-06-2017, 04:25 PM
JagV8's Avatar
Received 4,533 Likes on 3,942 Posts
Could be but you could try the kinds of things others have posted about (this forum / this site). Search will get you ideas that are much cheaper if they pan out.
Rais Mtukufu Gim (12-21-2017)
Old 12-21-2017, 08:40 PM
thanks
Old 12-22-2017, 04:11 PM
wa3ra's Avatar
Does Kenya have a tight emissions inspection?
If not, you can gut the cat, and add "cheaters" to the downstream sensors for much less than that convertor will cost.
Old 12-22-2017, 04:45 PM
innzane's Avatar
It shows a code for a faulty o2 sensor on that bank, if it is bad then the bank cannot be read correctly by the computer. It may be a just in case code if it cannot monitor the true data. You can try swapping the B1&B2 downstream sensors and see if the codes swap banks also.
Old 01-08-2018, 02:58 AM
we removed the honeycomb from the cat since it had melted. seems okay for now
