x-type 2.1 v6 2003 petrol P0346 replaced sensor no change HELP!!!!
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hey fellow Jag Owners looking for some more help pretty please. I have been getting the DTC code P0346 camshaft position sensor A-Bank 2 CKT range/performance. I have replaced the sensor cleared the code and nothing has changed still getting the same code. No idea where to go from here. Does anyone have a wiring diagram as I have had some advice that I need to check the wiring from the sensor to the ECU to see if there are any breaks nics etc, and check if the connection is grounded to the ECU.....how do I do this ??? Some help and a wiiring diagram would be greatly appreciated.
Also could any problem with the crankshaft sensor cause this ......just something another supposed expert has mentioned!! The concentric slave cyclider in the gearbox was changed apparently any oil / dirty that has affected the crankshaft sensor can cause the camshaft sensor to misbehave.
kmeseck
09-13-2017 09:25 AM
abartl22
01-04-2016 06:15 PM
likica
06-04-2015 06:07 PM
Xcellr8
05-24-2014 12:30 PM
