x-type 2.5 v6 p0037 dtc
Hello!
I Just bought a 2002 x-type 2.5 v6, and have the p0037 dtc code and check engine light coming again and again, following tops on other threads of this forum, I replaced the lambda sensor, downstream near the radiator with the correct oem denso part, but this didn't solved the problem...
What can I do?
Thanks!
What can I do?
Thanks!
ulmi - code p0037 is the downstream sensor (cat) on the rear bulkhead side nearest the windscreen/shield. Seems someone has got confused when telling you which 1. I kno for a fact because i had the same code come up few weeks ago and replaced and now is all good. Its the black connector plug situated at the right hand side of the engine by the intake manifold. I hope you have kept your other sensor! Ryan.
ulmi (04-16-2012)
Hello!
I tried, definitely not possible without the correct socket... So I ordered and it has come today, the job was done in few minutes; and the chek engine light did not came after a little test drive! So I think it's cool![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash2/156551_410713115613840_100000254642814_1555841_1042935895_n.jpg)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/528678_410713158947169_100000254642814_1555842_801912579_n.jpg)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/542895_410713228947162_100000254642814_1555844_698304425_n.jpg)
That was not without pain![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-prn1/555734_410713188947166_100000254642814_1555843_1950870564_n.jpg)
2 pictures of the car, I will do more then they will be clean, it's raining and raining...
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash2/154453_410712502280568_100000254642814_1555837_402938492_n.jpg)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/562590_410712565613895_100000254642814_1555839_1837596841_n.jpg)
thats good news! I bet it wasn't too bad using that special tool - i had to put up with a modified spanner, well saying modified, more like cut in half then a big tubular bar stuck in! But got their in the end!
Just out of interest, how much was that tool and any ideas where to buy one? Glad i was of a little help, but i'd say you done the hard part
like ur mx5 tho..
