X type air con bearing
Generally the clutch is sold with a complete a/c compressor. I don't know of an available clutch only. The removal of the clutch is fairly straight forward there is a nut on the end of the shaft. Remove it and install a clam shell type puller and you should be able to remove the clutch. There is a spacer behind the clutch be sure not to lose it.
Mainly the whole a/c compressor, if you shop around, is pretty cheap as a unit. Not really much need to go to the effort of changing a bearing only to find other problems with the clutch.
aircon clutch
the nut allows the removal of the clutch plate, under this is a cir-clip that holds the pulley unit. the pulley will just pull off once this is removed. under the pulley there is another cir clip that holds the clutch coil assembly. I've just taken one apart as the pulley had broken away from the centre part that holds the bearing.
