X-type anti-roll bars?
Received 3,887 Likes
Ian, there are no aftermarket anti-sway bars that I am aware of. As for body roll, mine doesn't roll hardly at all. have you made sure that you haven't broken the rods for the sway bar? That could cause what you are feeling and then it would be an easy fix. The rear rods are prone to breaking.
Ian, if you can get under the car, it will be very easy to spot. Just locate the sway bar and follow it all the way to the lower A-arms. If you can make it all the way to the top nut and not scrape yourself on something, then odds are things are doing good.
The other thing that I will tell you to take a look at is the mounts where the swaybar is mounted to the body. Some members have actually had these fail and that could also lead to what you are feeling. Again, this is a very easy thing to spot as you will see the angled metal bracket and near the 90 degree bend, you will see where the metal has sheered/cracked.
Ian, it will be easy once you get under the car. You will see the 7/8" bar running from side to side. You will also see the vertical posts that I talked about earlier. As for the supports for the sway bar, those are really easy as they are the two big bulges that are wrapped around the sway bar. When you get under the car, it will make a lot more sense.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
