X-type ATF-Information from Valvoline
Hi Guys, I thought the following might prove useful to those of us who plan to change the ATF fluid:
Workspace: Valvoline Product Support Incident: Valvoline.com New User Registration Incident Number: 21637
Status: Closed Date: 12/03/2011 Time: 11:43:32 Creation Date: 12/03/2011 Creation Time: 11:14:44 Created By: feedback@valvoline.com
Description:
Thank you for contacting Valvoline Product Support. For your 2007 Jaguar X-Type application, we recommend the use of our Valvoline MaxLife Dex/Merc ATF product to meet the LT71141 specifications recommended by your manufacturer. If you have any further questions, please feel free to contact us via email or by phone at 800 TEAM VAL. Thank you once again for contacting Valvoline Product Support.
Incident Information:
Submitted Via: Email
Contact Information:
First Name: Consumer
Description:
The X-Type uses the JATCO JF506E. The ESSO LT71141 is NOT THE CORRECT FLUID.
The LT71141 is for the ZF 5HP24 gearbox ONLY!!!!!!!!!!!!
You can use Audi/VW fluid for the 09A 5 speed because it is THE SAME GEARBOX.
You can also use Castrol Import Multi-Vehicle as it meets the same specs for the JATCO gearbox. Land Rover uses this gearbox also.
The Valvoline fluid might be fine but they are saying that it is compatible with LT71141 and that is NOT USED in the JATCO gearbox.
JATCO fliuid is RED and the ESSO LT71141 is a 'golden color'.
bob gauff
bob gauff
Jaguar NEVER recommended ESSO LT71141 for the JATCO JF506E.
The correct part number for the Jaguar fluid is C2S 12120.
People can put whatever they want in their cars.
I use the Jaguar fluid or Castrol Import Multi-Vehicle ATF because it meets the specs.
I work on a lot more VW 09A transmissions (solenoids and fluid changes) than Jaguars.
The VW fluid is G 052 990 A2 so I guess you can use it also.
bob gauff
bob gauff
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
