X-type battery reconnect= transmission fault & no start
Old 11-08-2014, 09:17 AM
Joshy's Avatar
Default X-type battery reconnect= transmission fault & no start
CHANGED DRIVER'S SIDE HEADLIGHT BULB. Took out battery, unplugged necessary connectors, reassembled. It wont start! Lights work now, why how what is this? Advice anyone? 321-848-3013 Jules, Joshy's dad,
Old 11-08-2014, 09:35 AM
sawduster's Avatar
Did you check the fuse for the transmission control module? Also check the connectors to the TCM to make sure they are clean and not corroded. It sounds like it could be an electronic problem with the TCM and so I would start there.
Old 11-08-2014, 12:12 PM
Joshy's Avatar
tried to check the tcm and then I realized I don't really know what I'm looking at. It all just looks like plugged in wires to me. I don't see anything that it seems like I shouldn't.
Old 11-08-2014, 01:06 PM
sawduster's Avatar
The TCM is located above where the driver's left foot would be, way up and back in the left corner. You can search "x-type TCM" on ebay to get some good pictures of what one looks like.
Old 11-08-2014, 01:09 PM
sawduster's Avatar
By the way, since removing and re-installing the battery caused this problem, you should double check the cables and connections and make sure they are clean and tight. Even thought the lights work, the module may not be getting the full voltage.
JarodL
03-07-2024 01:39 AM
way2far
08-31-2022 09:26 AM
Shawn Svacha
11-04-2019 02:47 PM
tberg
09-07-2015 07:32 AM
laserguy
09-03-2015 02:02 PM
Quick Reply: X-type battery reconnect= transmission fault & no start
