X type braking problems
I have a 2001 x type 3.0 SE, sometimes when braking the pedal judders as if the ABS is operating. However it always seems to happen when road conditions are good i.e. no ice or rain. Also the ABS light sometimes glows orange for a while and then goes off, but strangely the light never comes on at the same time as the juddering.
I would appreciate any advice on what the problem may be. Thanks.
Received 3,887 Likes
Alan, from our experiences with the car in question, you are looking at a failed ABS speed sensor ring in one of the rear hub assemblies. You can remove the ABS sensor from each of the rear wheels and look down inside the hole. You should see a toothed gear at the bottom of the hole. If you don't see it, then you need a new CV axle to get a new gear. If you can, find a shop that can read ABS codes and see if you can get help there to narrow things down to a single wheel. Truely it can be any one of the 4 wheels, but experience has shown about 99% of the time it is a rear wheel that is causing problems.
BrentGardner
28
04-26-2024 03:08 AM
stanjag
08-30-2015 10:35 AM
Terrance Williams
08-26-2015 11:50 AM
