X-Type Check Engine Light
Received 3,894 Likes
Jon, I would venture to guess that you got some oil down in the spark plug wells near the fill hole. What you will need to do is to remove the air box from the car so you can access the plug wells on the front side of the engine. Then you will need to get some sort of rag or the like to wipe up the oil out of the wells. May want to also get a little bit of degreaser to help remove the oil from the COPs.
That should hopefully cure what ailes the engine. But, like was mentioned, getting the codes will help isolate down the problem(s). But, I would venture to guess that you would be getting the P0304 and P0306 codes.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
