x type electrical fault
After having a repair done to my 05 diesel x type which meant i had to remove dash and screen,before removing these it started up first time and everything worked perfect the lad who took the dash out and screen as said everything has gone back how it should but i have nothing on the key and clock is dead does any one have any ideas or does some know where i can get a wiring diagram.i have had a auto electrician looking at it but he is scratching his head and cant get to the bottom of it,please please someone help getting to the end of my tether
Received 3,887 Likes
Working with connectors a lot at my work, it may be possible that all the connectors went back together fine, but one of the pins got pushed back into the plug due to not properly aligning the plugs. This would cause what you are seeing. Unfortunately, the only way to find this is to take each plug apart.
Alto, as for your issue, when you say you have nothing at the key, just what do you mean by that. Are you saying that when you open up the door, you get no lights? Are you saying that when you turn the key the car does not start? where do you have power and where should you have power that you don't. From the sounds of things, it is sounding like a connector got knocked loose. But, I need to know where there is power and where there isn't. I have the diagrams for an 04 and that should allow me to point you in the right direction.
alto, i know this might sound funny, but at a quick look, it is sounding like you have 2 plugs criss-crossed. Sounds like one of the plugs that is crossed is the one you unplug for the reverse lights. Then the question is where is the other plug that needs to be undone. BUt, I will take a look and see what I can find.
