X Type Fuel filters
Good Day & A Happy New Year To all Members
Anyone give me information on the location of my fuel filter. Is there ONLY ONE ?
I had the idea there were two located below the rear seat - if so is there access from inside vehicle or does the whole suspension assembly below have to be dropped to get at them ?
Good old X type never going to give a sucker an even break.
Thanks & kind regards
Received 3,922 Likes
ray, there is only 1 fuel filter for the car. Accessing it is really easy. The fuel filter is located on the underside of the car by the rear tire. If you are looking at the front of the car, walk around to the left and stand by the rear tire. If you jack up that tire and then crawl under the car just in front of that tire, you will see the fuel filter mounted on the vertical wall there. 2 bolts and the fuel filter comes off of the body of the car. Another bolt and the filter itself can be removed from the mounting plate. From there, you will need a special tool to release the retaining clips for each end of the filter.
Replacing the filter takes very little time. Go for it. The special tool should be available at your local auto parts place. They will probably call it a "Ford fuel line removal tool". It costs $10 USD. So, it is a fairly inexpensive tool.
rayclark1 (01-06-2015)
+1 and here is a link to the fuel filter if you want to buy it:
jaghelp.com: Jaguar X-type recomended fluids
X_Type_South_Africa
12-09-2015 05:37 PM
stanjag
08-30-2015 10:35 AM
