X type headlight problems
Old 11-15-2015, 01:56 PM
EastFalk's Avatar
Default X type headlight problems
I was replacing my headlights in my 2004 x type. The contact broke off in the wiring harnest i tried to remove it with needle nose pliers and it would not budge please help I'm on a budget I'm not sure what to do or where to go. Is it in my best interest to go to the jaguars dealership and spend the money or is this something I can fix on my own. I'm open to suggestions just need help.
Thank Easton.
Old 11-15-2015, 05:04 PM
dwclapp's Avatar
Easton: If you're asking about the electrical connector supplying power to an incandescent headlight bulb (not HID's), the replacement connector in this picture will be easy on your wallet.
Be careful not to push or pull too hard on the headlight bulbs. It's easy to break plastic tabs inside the headlight that hold and aim the bulb.
If your bulbs have a good ground, then don't worry about the soldered wire in the picture. This post tells that part of the story: https://www.jaguarforums.com/forum/x...4/#post1053650
Attached Thumbnails X type headlight problems-jaguar-x-type-headlight-electrical-connector.png
EastFalk (11-15-2015)
Old 11-15-2015, 10:23 PM
EastFalk's Avatar
Oh my gosh thank you so much I will most deffinantly try this before I take it to the dealership for them to fix it!!!!!!!!!
Old 11-16-2015, 01:11 PM
Paulc732's Avatar
This may help.
you can use a regular soldering iron and lighter for the heat shrink.
damnJag
11-03-2015 07:38 PM
nick128
10-27-2015 12:24 PM
dollison
10-24-2015 04:21 PM
diablomkii
10-21-2015 09:45 PM
DaveInVA
10-21-2015 03:33 PM
Quick Reply: X type headlight problems
