x-type HID fogs adaptor...help please
so i ordered a bunch of H1 hid kits.
they look like they need a bulb adaptor clip of some sort to put them in.
has anyone on here had this issue and is so please post a pic of it or a link to the adaptor.
my supplier has never had this ussus but is looking for a adaptor base clip as well
does anyone have a bmw with h1 bulbs or a nissan altima or any other one they put hids in
can someone post up a pic of the factory base of the h1 bulbs online all i can find is the bulb with no base.
i really dont want to pull that skid plate off again untill i have everything..also now i have to change more headlight bulbs..the drl's burnt out.
Received 3,910 Likes
That is what I was thinking about doing actually.
Now the H1 bulb, why is it like this for the jag? Will the H1 hid bulb need the same modification to the origional bulb base even on other cars?
I need to put them in fogs of the jag and altima headlights.
I tried to put in a 9006 and it almost fit the fog, I didn't try too hard though, I got it in but it wouldn't turn and lock.
MIke, I would think the same sort of modifications would be needed for both cars. The main problem (atleast with the kit I got) was that the bulb had the wires hard mounted to the bulb. So, there was no way to "plug" the bulb into the factory base and then plug the wiring into the base. I discovered atleast with my kit, using a 1/2" drill bit works perfectly. It was just large enough to fit the plug for the light through, yet small enough that there wasn't a large gap around the bulb for gluing it into place.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
