x-type idle setting
diggerdegraves (01-14-2011)
You shouldn't have to, have you checked for vacuum leaks? I think there is an adjustment around the MAF but you should never need to touch it since it's set at the factory. I would check into more what could cause it to drop. My vote is vacuum leak. At the brake booster is one of the most common. Search this forum for vacuum leak and it will fill up 10 pages. There is another thread that I told the guy to search dennisblack for a picture of the most common areas of leaks.
Received 3,886 Likes
Digger, with the engine cold, the idle should be around 1000-1200 with the car in park. In drive, you should see it around 700-800 RPM. Then as the car warms up, you will see it drop to around 700 RPM in park and 600 with the car in Drive.
As for adjusting the idle RPM, got a really fancy computer with the OBD writing software on it? The idle is not adjustable unless you get in and adjust the programming of the ECU. If your idle is low, then you may find that your throttlebody has some gum built up on it (but this is normally shown by an erratic idle, not a low idle) or you have a vacuum leak.
thank you for the info. i am trying to chase down the vac leak. sorry so late on this reply. working long hours these days. 0530 - 1600. hard to find time to work on the car. might have to wait until it warms up a bit.... to damn cold to be under a hood right now, and my garage has too many toys inside. cant even park the jag in it. might have to build a bigger garage.lol thanks again for your help
aholbro1
08-05-2021 05:02 AM
Thang Nguyen
10-12-2015 01:25 AM
WTB[NorthEast]: X-Type Sport Wheels
Whitnessmouse
09-04-2015 11:09 AM
