X Type Jaguar Stop Light possible fault
Received 3,901 Likes
Joseph, odds are, if you look under the dash near where the clutch pedal is (above the clutch pedal), odds are, you are going to find that either the linkage or other moving part of the clutch is coming in contact with a wire bundle and it just happens to be cutting on your brake lights. Should be a fairly easy fix. The trick will be finding the wire bundle. Getting your head under the dash can be a bit tricky. The easiest way I have found is to lay the seat all the way back and sit in the seat upside down (ie, head in the footwell, feet by the roof).
Wish you luck.
Wish you luck.
BrentGardner
28
04-26-2024 03:08 AM
Isoruku
06-19-2020 12:54 PM
stanjag
08-30-2015 10:35 AM
NinoGrimace
08-26-2015 05:15 AM
