X-type Jerks and gives a thud when stepping off and on the gas.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hey Guys,
I have a 2004 X-type 3.0 Sport with 97k miles on it.
When i'm at speed, let off the gas, and re-apply it, the car gives a little thud from underneath along with a small jerk. I was wondering if it could be a broken motor mount possibly? Any Opinions?
Thanks!
Thanks!
![Icon Slap2](https://www.jaguarforums.com/forum/images/smilies/icon_slap2.gif)
When the car is stationary and the car is rocked backwards and forwards is the noise pronounced and can it be felt through the wheels. If it is not the U J it could be rear subframe mounts which are a known issue, they are located forward of the rear wheels and attach the subframe to the body with a large flat bush, this gives up and allows movement in the whole frame, replacement is relatively easy with the right tools.
edge1212 (09-26-2011)
Thanks for your suggestions guys, I took a look at those areas. Found that the driveshaft had a lot of slack in it. The U Joint connecting the two sections of driveshaft in the middle of the car is worn. Unfortunately the UJ is non-replaceable so looks like i'll need a new driveshaft. >_<
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
