x type noise
Old 10-18-2018, 03:10 PM
rci2990's Avatar
Banned
Default x type noise
hello i have a 2005 x type that has been making a noise that is similar to the airplane noise that people say is the driveshaft bearing. i put grease in it but made no difference.noise starts around 25-30 mph and stays constant after that. if im driving straight it like comes in and out but if i turn steering wheel left it goes completely away and if i turn right its there constantly and doesnt go away till i turn left. i checked the play in wheel bearings and there isnt any. i changed the tranny fluid and xfer case fluid about a year ago. and this noise problem has been going on for about 2 months. i dont want to start throwing money at this. any ideas?
Old 10-18-2018, 03:50 PM
Steve M's Avatar
Received 3,100 Likes on 1,726 Posts
Can you feel a vibration through the steering wheel when the noise is present?
If so it is probably a front wheel bearing; mine does exactly the same.
Old 10-18-2018, 05:21 PM
rci2990's Avatar
Banned
you can feel it in steering wheel shifter knob pretty much in whole car. i made a audio recording of it and have to figure out how to put it in post. but you can clearly hear the noise at anything over 30 mph and just jerking the wheel to the left make it go away till i bring wheel back to center.
rci2990's Avatar
Banned
sounds like a plane taking off.
Old 10-18-2018, 09:01 PM
Dell Gailey's Avatar
Left Wheel bearing
Old 10-18-2018, 09:27 PM
Thermo's Avatar
Received 3,932 Likes on 3,228 Posts
I am with Del on this one, sounding like a left front wheel bearing that is going bad. If it isn't that, then I wold be looking at the CV shaft then on he same wheel.
Old 10-19-2018, 02:41 AM
rci2990's Avatar
Banned
ok thank you im gonna see where i can get it in my area and replace it.
Old 10-19-2018, 04:52 AM
iownme's Avatar
i thought the direction of steering which makes the noise = bad bearing....i.e if the noise occurs while turning right, then its the right bearing?
i just replaced my right bearing as it made noise when turning rigjht..:cured mime
Old 10-19-2018, 04:54 AM
iownme's Avatar
bear in mind a cv joint will make more of a clunking or clicking when turning
Old 10-19-2018, 09:47 AM
Thermo's Avatar
iownme, my experience is when you turn in the direction of the bad wheel bearing, it unloads the wheel, removing the pressure on the bearing, causing the noise to reduce/go away. Turning the other way adds more pressure to the bearing and will cause the noise to continue. Same thought can be used with CV joints, but in this case, what happens is the wheel on the inside starts turning slower, causing the engine power to the shifted away from it, reducing the strain on the CV joint, reducing the amount of noise it will make.
Old 10-19-2018, 01:48 PM
That's funny, I always had experience that the turn that caused the noise to increase indicated the opposite wheel problem. But here was my thought process = didn't unload the pressure but increased it. So bad left, turn right, weight of car shifts to the left causing more load, lol. Guess my thoughts were wrong. The end result is still the same.
Old 10-21-2018, 06:54 AM
iownme's Avatar
maybe not a hard and fast rule.
i had a terrible noise and vibration which only went away when turning right, replaced the right hand front wheel bearing and all was cured.
but my car is cursed so that may be the reason.
i advise....buy 2 bearings
Old 10-21-2018, 01:50 PM
Is your car named Christine? :-) :-) :-)
Old 10-21-2018, 03:24 PM
iownme's Avatar
all the "signs" told me not to buy it....but that goddam carbon fiber dash kept winking at me!
Old 10-21-2018, 03:44 PM
Steve M's Avatar
I would advise changing both wheel bearings because if one is worn then the other one won't be far behind.
Unless you just drive on an Indy car circuit of course.
Anybody know how many miles that you can do after the bearing starts making a noise before it fails completely?
Old 10-22-2018, 05:17 AM
iownme's Avatar
mine was bad for at least 1000 miles, it didnt fail but did get loud
Steve M (10-22-2018)
Old 10-22-2018, 12:42 PM
Steve M's Avatar
Ok, thanks.
I've done over 500 miles since mine started squawking and it is getting louder and more noticeable on the steering wheel.
It's in for replacement tomorrow.
Old 10-23-2018, 07:53 AM
Steve M's Avatar
Great, they can't get the drive shaft out so I'm a bit screwed.
They reckon that it is seized in solidly and even heat won't shift it.
Old 10-23-2018, 03:45 PM
iownme's Avatar
i recently went through that with a rear bearing
Old 10-23-2018, 03:48 PM
iownme's Avatar
https://www.jaguarforums.com/forum/x-type-x400-14/rear-hub-stuck-halfshaft-208264/
post #14
Quick Reply: x type noise
