x type noises?? 02 2.5
Old 10-08-2006, 04:25 PM
Default RE: x type noises?? 02 2.5
WOW! only 14mpg, I average about 21mpg. Sounds like you might have some issues...
Old 10-08-2006, 10:55 PM
BuckMR2's Avatar
I get more MPG in my 3.0 even allowing for difference between US mpg and GB mpg.Could it be overfuelling if there is an air leak in the intake?
Old 10-09-2006, 01:49 AM
nineball's Avatar
i had the same 'turbo' noise on my 04 2.5. the dealer just replaced the front transfer case under warranty. it is more quiet, but not as quite as an auto.
Old 10-09-2006, 06:49 PM
BuckMR2's Avatar
ORIGINAL: mbroker
Whats with the scream avatar?
Its either:-
1) a picture of me getting up and taking a photo in the mirror after a Friday night out in the party capital of the world (Newcastle-Upon-Tyne to all those uninitiated)
or
2) just because its a bit different to everyone elses and what I can turn into behind the wheel[sm=yikesomg.gif]
Old 10-10-2006, 07:44 PM
racerx82's Avatar
Could be one of two problems and without really hearing it, i'm gonna guess.
1- exhaust leak....(if it was an intake leak, your car would die at idle..and would run like crap at cruising speed). Check your mufflers, exhaust and exhaust manifold. i heard stories that the right side cat tends to crack...makes the same noise.
2- possible timing chain on one of the cams is messed up....
like i said without hearing it...very difficult to diagnose...
have you tried your local garage?
________
ZOLOFT CLASS ACTION LAWSUIT
Old 10-11-2006, 01:00 AM
racerx82's Avatar
Fuel filter in rear, under car car about 1/4 way past fuel tank. timing chains are on pass side (right side) where the serpentine belt is, behind that cover.
________
Cat Wheels
Old 10-11-2006, 07:05 PM
racerx82's Avatar
Yeah, that could be it also....like i said..really hard to make that call without see and hearing. Alternater bearing can also make that sound........just gonna havta wait it out and catch it at the right time
If it was the water pump, it usually starts to leak when making any noise....power steering pump can cause difficultly in steering...(hard to turn the wheel at idle)
I suppose you can put a load on all....try this....start car, turn on all lights (high beams too) air conditioning also, heated seats if you have it and rear defroster...this will put a load on your alternater and A/c compressor....if it's bad you should hear that noise.....
at same time, turn wheel left and right...test your powersteering pump out......any noise?
as for the water pump, check for leaks under car over night....
________
Fix Ps3
Old 10-11-2006, 07:22 PM
racerx82's Avatar
Yeah, that is kind of weird...with a temp drop it should get louder...not quieter lol...
You didn't notice any leaks on the left hand side from car?
________
Prilosec side effect
Old 10-11-2006, 11:20 PM
racerx82's Avatar
Yes, alt is on right side....as for the dimming, it's normal under the heavy load at idling....
Well i suppose next time you hear it, pop the hood open and try to see where it's coming from...
________
Paxil injury lawyer
Quick Reply: x type noises?? 02 2.5
