X Type p0301, p0303, p0305 ,p0174
I have a 2004 X Type. Car idles fine and runs fine unless I step on gas then it sputters and check engine light blinks. If I let off gas the light stops blinking and car runs fine again until I step on gas again. I have changed the IMT o rings but no change in performance. Here are codes its giving me. P0301, P0303, P0305, P0174. Is there a way to check for clogged cat converter. Thanks for any help.
Based on the codes you have a Cylinder 1, 3, & 5 misfire. These are located in the harder-to-reach area. When facing your engine from the front of the vehicle the cylinders are the three toward the back (See picture).
p0301-Cylinder 1 misfire
p0303-Cylinder 3 misfire
p0305-Cylinder 5 misfire
p0174-System Too Lean Bank 2
My first reaction is that you may have oil on your spark plugs. Clean or replace them. Second reaction is that you may have a vacuum leak (keep reading).
If it is a vacuum leak you can test it by starting your engine and letting it idle. When in idle spray starter fluid near the hoses or anywhere you may think there is a leak. If the engine revs on its own when spraying then you have a leak.
If not then my next suggestion is checking the breather hose and all other connection that lead into the intake manifold.
Sccooters (03-12-2015)
Thanks Guys, One more question. I'm assuming that intake has to come off to get at those plugs. How involved time wise is that task and is there a gasket underneath that would head to be replaced. I bought the car for my son a couple years ago to go back and forth to college so I'm not that familiar with it cause I don't drive it. Thanks again.
Refer to this thread: https://www.jaguarforums.com/forum/x...nge-faq-48128/
You are looking at a 30 min job to get to the plugs if doing this for the first time and about 6 minutes if you know where all the bolts are.
Refer to this Vid if it helps:
Sccooters (03-14-2015)
Update, so I finally got around to changing plugs (I must say it took me a while longer then 30 minutes) all six plugs looked good, no oil, good color, gaps were a little off. I also took the coils from bank 1 and moved them to bank 2 to see if maybe that was problem, but took it out for a test drive and same thing. Car stutters when you get on it and check engine light blinks, if I let of gas light goes out and car runs fine again until you stomp on gas pedal. Checked codes when I got back and same codes came up again. I'm ruling out plugs and coils, I checked for vacuum leak but couldn't find anything and I'm thinking if it was a vac leak wouldn't it affect all 6 cylinders? Any advice on where or what else could be causing this. Thanks for any help.
Scooters,
Did you find the root of the problem? My wife drove through a puddle after a rain storm and now our 2004 x-type (3.0 6 cyl), the car runs rough when I start it and there is a fuel smell. The codes are p0301, p0158 and p0303. Their not the exact same codes you had but I wanted to see what the possible solution could be. Any feedback will be helpful.
I was the first 4.2L STYPE PROTOTYPE. Came out perfect. I replaced both<br/>
Sorry for updating such an old thread but I stumbled on this looking at P0301 errors and I wanted to point out the last post here saying a rear catalytic convertor can be replaced with a $50 install is NOT for the X-Type, this part and repair estimate are for an S-Type. Replacing the rear catalytic on an X-Type will require $50 in band aids, many apologies to the neighbors for teaching their kids bad words, and at least some psychiatric therapy when you are done.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
