X-type Propshaft centre carrier bearing
Old 10-19-2012, 11:39 AM
jaguar.awd's Avatar
Default X-type Propshaft centre carrier bearing
It is not possible to buy original new "centre carrier bearing" for Jaguar X-type, because Jaguar sell ONLY complete Propshaft.
Does anybody know ALTERNATIVE ways?
OK, one way is to buy used (not easy) or used complete Propshaft.
Which dimensions of X-type "centre carrier bearing" are? Inside raduis? Outside radius? Wide?
Is that "centre carrier bearing" mada by "*****" ?
Which car has COMPATIBILE or very similar "centre carrier bearing" (with equal dimensions) , what is possible to put on X-type Propshaft?
Thanks for answers.
Lcgi (10-19-2012)
Old 10-19-2012, 02:01 PM
Lcgi's Avatar
I would also be interested in all responses to this topic..... along with any Jaguar TSB covering the procedure
Has anyone who has replaced or worked on this bearing.... bothered to put a grease-nipple in it ?
Old 10-19-2012, 02:22 PM
Luka's Avatar
65X100X18 in millimeters
Bearing Type 6013-2RS
Lcgi (10-19-2012)
Old 10-20-2012, 06:58 AM
jaguar.awd's Avatar
Luka, velika ti hvala!
I found million of peaces for Bearings Type 6013-2RS (65X100X18 in millimeters). What would be NEXT?
To find, all cars with bearing "6013-2RS" inside "centre barrier bearing", which is possible to buy SEPARATE.
Some of them have places (holes) for FIXING on similar places. like X-tipe. But, it would not be big problem. Isn't it?
In all cases, after every work with propshaft, it is very important to make BALANCE of propshaft!
QUESTION:
Who does know which type (types) of a car (exept all Jaguar X-types) has "centre barrier bearing" (for propshaft) with bearing "6013-2RS" (65X100X18) ?
Old 10-20-2012, 10:49 AM
DA-X's Avatar
Old 10-20-2012, 11:20 AM
Luka's Avatar
It is not necessary if you do not disassemble the two parts of propshaft (central universal joint)
QUESTION:
I did this investigation ten months ago and didn't get any helpful results.
So I just replace the bearing inside only.
Very difficult operation. I do not recommend doing this if you have no great skills in this field.
But I made ​​it and it works very well.
Attached Thumbnails X-type Propshaft centre carrier bearing-resize-cimg7366.jpg   X-type Propshaft centre carrier bearing-resize-cimg7367.jpg   X-type Propshaft centre carrier bearing-resize-cimg7368.jpg   X-type Propshaft centre carrier bearing-resize-cimg7369.jpg   X-type Propshaft centre carrier bearing-resize-cimg7371.jpg
The following 3 users liked this post by Luka:
blaydes99 (01-04-2013), Panthro (10-04-2020), Patriot_Red (01-04-2013)
Old 10-20-2012, 12:38 PM
jaguar.awd's Avatar
Fantastic INFO from DA-X !
They sell "original" bearings:
Center bearings replacements, better than OE, save money! - Drivetrain.com .
It is 200 dollar + shipping .
Also, has to buy 2 gaskets for propshaft (about 65 dollars, shipping including).
Then go to expert, who knows to split propshaft and to change carrier bearing.
But, I will do this.
I found on ebay complete used propshaft for model 2001 X-type, just for for 70 british pounds. I think, IT IS AVAILABLE for 2004 X-type . Isn't it?
Of course, I need to buy 2 gaskets for propshaft (about 65 dollars, shipping including).
And go to service.
Old 10-21-2012, 06:01 AM
jaguar.awd's Avatar
In previous post word COMPATIBLE is better than "aveilable".
But, what is this:
Center Supports - JAGUAR X-TYPE 2002 - 2006 - Driveshaft Parts
Also, on both sides (front, rear) of propshaft should be one BEARING, but different than "center bearing" .
I hope, those bearings are same. Who does know, exact term for that bearings?
Please for the LINK. Thanks.
Old 10-21-2012, 09:36 AM
Luka's Avatar
The correct term is not available, because for this part there is no OEM part number.
But that's exactly what you need.
Old 10-21-2012, 11:22 AM
jaguar.awd's Avatar
Hvala ti Luka. Poslao sam pitanje za "Driveshaft Parts" . Cijena je tu 85 dolara. Na "Drivetrain.com" je cijena 200 dolara. Velika razlika u cijeni. Sumnjivo mi je to.
Lcgi (10-22-2012)
Old 01-04-2013, 05:23 PM
Patriot_Red's Avatar
Good info thanks
Corycarlo
10-03-2015 09:33 PM
JAMES1944
09-29-2015 11:58 AM
Col. Sandurz
09-28-2015 07:29 PM
the guardian
09-25-2015 03:06 PM
Quick Reply: X-type Propshaft centre carrier bearing
