X type rear diff broken
Received 3,909 Likes
I would be placing my money on a transfer case than on the rear differential. That is much more likely to fail and give you the indications that you are seeing/hearing than the rear differential. Unless she bottomed out the car and hit the rear differential, the transfer case will give long before the rear differential.
I notice that there was a slight leakage coming from the aluminum pan towards the back middle - I was afraid that it might be transmission fluid but a freind of mine said it looks like its the rear differential due to the unit was coverd with dried up fluid - is there any way to find out or test what might be the leak - also if its the rear differential what type of oil it needs -
stanjag
08-30-2015 10:35 AM
