X-type Rear entertainment systems on sale!
We have complete factory X-type rear entertainment setups on sale right now for $250.00
I have plenty of all colors right now.
check out the special on our homepage.
www.GaudinJaguarparts.com
-David
-David
Received 9,007 Likes
pnyklr- this is a complete setup including headrests with moniters, everything needed to install, headphones, remote, and the input bracket that installs on the rear of the center console. There is no built in DVD player, but there are multiple RCA inputs, and a memory card slot.
Disco stu55- It is on a dropdown list with the S-type, you can pick your model and color.
JimC64- thanks! I will let you know if I get any other good deals.
-Thanks
David
-Thanks
David
Do the headrests come in specific colors?
Is that $250 each or for both?
So basically I would replace the headrests
and how would I wire this up to make it work?
wiring is not a problem for me I woudl need a DVD player or something else to plug into the RCA jacks that would provide a video signal
I guess I would also have to somehow tie the monitors into the speakers in the car as well?
pnyklr-
The headrest come in most interior colors. I encourage you to look at the speciial on our homepage for more information
Yes, this includes both headrest assemblies with monitors.
The kit includes everything required to install, and instructions.
As far as I can tell it does wire into your car audio system. There are two wireless headphone sets included.
-David
-David
Seems like a great price. But another option is simply hand out iPads to the rear passengers! $1000 get's you 2 and if you get a Verizon Mifi device you can actually stream Netflix or watch live TV.....you can use the headphone or connect one through the stereo via the ACM (you can connect the ACM to the bluetooth receiver for a full wireless connection of an iPad to a audio via the car speakers). That's how my car is set up!
It doesn't, it can only be used with the wireless headphones.
This system just pulls power from the car.
I installed mine (not purchased through this thread) and took about 1.5hrs from start to finish.
I am very competent, and the average person with basic mechanical ability, could probably do this in 3-4hrs
Does anyone know if these screens will be compatible with an after market dvd unit? I have a double din with a dvd player built in, and has rca outputs. just not sure if i can directly hook up the screens to the dash, or if i would have to run wires from the connection port that is provided with the package?
Thanks in advanc
Thanks in advanc
Last edited by 04Xtype; 11-20-2010 at 04:23 PM. Reason: Answered in a different thread
I think you would have to use your current indash dvd player like a portable dvd unit. By this i mean plug it into the supplied connections with the rear unit(leaving a video lead wire out in the open) unless there is a video jack you can run straight into the back of the connections from the rear unit making it not usable to a portable unit. this was my same question i have a dvd in dash now but if it did work, all screens would have same movies all the time not one in the front and another movie in the back from a portable dvd unit
philwarner
09-05-2015 10:05 AM
innzane
09-02-2015 10:08 AM
