X type suspension help
First, the struts should match the car. If you have a sport, you'll have sport struts, if not, not. Also, the struts are stamped on the cylinder shafts. You'll see a STD on the standard ones in fairly large lettering, forgot what the Sport says. Another, I think, but cannot recall for sure, there are two colors - Green, blue. They also indicate the type, but for the life of me I cannot remember which is which.
Watch for a reply from THERMO, he might weigh in and is very knowledgeable on Xs
Received 3,887 Likes
jaguarNeWb, a quick check is to look at the front of the car. Do you have chrome strips on the corners of the bumpers or are the color matched to the car? The same check can be done for the surround of the grille. If it is chrome, then you have the standard X-Type. If they are color matched to the body, then you have a Sport model. From there, you can get the correct struts.
If you have more questions, just ask.
