X type Trans swap 2006 into 2002 DTC codes 61165-61175
I installed a 2006 automatic trans into my 2002 x type with 3.0 engine. My car is the early version on the vin #. Trans works fine but my speedo doesnt work and my abs light is on. DTC fault codes from my basic code reader are 61165 and 61175. I have never seen a code starting with 6 before. I was thinking that the trans module out of the 06 might correct the problem. Any ideas if this will help or what the codes stand for??
I have never seen a code starting in a 6 before either. I have also never seen a 5 number code either. All jag codes I'm familiar with are shown in this way A####. Maybe your code reader thinks that 6 stands for a letter? If I were you, I would go with the new tcu, but I would read the codes first before you pull the trigger just to make sure everything else is going smoothly
stanjag
08-30-2015 10:35 AM
