X-Type v6 air intake sound on idle
Old 10-06-2021 | 11:33 PM
h2o2steam's Avatar
Hi x-type_lpg,
If you are still tuned into this thread can you please elaborate on the "air flap valves" you referred to on your post #20 of this thread ?
Were you referring to the throttle body butterfly interacting with the idle air valve?
Or were you referring to the single IMT valve the 2.1 manifold has?
I get a sense of slight engine hunting on low RPM during deceleration on mine, which seems to resolve I suspect when the idle air valve is stabilizing its position.
But I recall another recent thread of another member trying to identify an induction fluttering sound after releasing throttle (high intake vacuum) and engine RPM decay.
Old 06-18-2022 | 11:02 PM
michaelireland's Avatar
Default same thing
IAC vanve on top of throttle body is stuffed. I had the same thing. Cleaned valve halved the problem. Got new valve
h2o2steam (06-19-2022)
cissdm
05-03-2016 07:02 AM
vwbusbits
10-13-2015 04:43 AM
jospolice
10-02-2015 08:16 PM
simo5555
09-09-2015 07:22 AM
Quick Reply: X-Type v6 air intake sound on idle
