x type weird speedo/dash problem
x type 2003 diesel
hi ive got a weird problem thats doing my head in now,
after 30-60 min of running my dash clocks go off, speedo and rev counter drop and all the lights come on as if you have just turned the ignition on. car will remain running with no loss of power and everything else on the car still works.
if you turn the car off (when problem kicks in) the car wont start again and the red light by the traction button lights up, if you wait for a min or 2 you can hear the clocks reset and the car restarts. and clocks return sometimes for an hr sometimes just a min then the clocks go off again. you dont have to be driving for the problem to start as i left her running without moving her and still get problem.
can a dieing battery cause this as ive heard jags do wierd things.
please help
please help
Received 3,887 Likes
hoff38, it sounds more like you have an issue with the electronics in the instrument cluster and that is causing your cluster to have the voltage drop some, making the computer think that the car is starting and it will cause the lights to come on (going through a diagnostic check). Then, if you turn off the car, the electronics in the instrument cluster are still warm and the voltage is low enough that it can't accurately pick up the signal from the key which will then cause the car go into a security phase and not start the car. After a little bit, the electronics will cool down and allow things to operate normally. I bet you will find if you run the interior of the car very warm, the time to cause things to act up will be very short and if you let the interior be very cold, it will take a long time.
hi thermo
yes you were right it takes longer to happen if heaters on cold. also in the last week as the weather is warmer it has happened almost straight away after starting and today wouldnt start . the car was parked in the sun today . i left the door open for a min or 2 and it started. the dash was hot to touch as you would expect from being parked in the sun. does that still sound like dash clocks to you? and do the replacement have to be from the same model and spec. mines a diesel but my local scrap yard has a 2.5 petrol. thanks for your help
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
Ophitoxaemia
09-14-2015 02:40 PM
stanjag
08-30-2015 10:35 AM
