X-Type: What is "the vacuum hose" behind the throttle body on top of manifold?
SOLVED: What is "the vacuum hose" behind the throttle body on top of manifold?
SOLVED:
Part Number: C2S16505
Price Range: $100.31 at gaudinjaguarparts.com/ - $164 at Shady Dealerships
(It's the hose in the top right corner)
Verify if it connects to #9 (Purge Valve) in Post #3:
You may need some rings. Part #C2S15816.
Caution: The hose I've received was assembled backward. It would fit if the purge valve will move.
In conclusion:
-The idiots at Jaguar needs to update their Official Catalog so we aren't wasting time and money on this damn wild goose chase and missplacing my loathing with the dealerships who were willing to help but had to ask around to find the part. I'm sure it's not going to be the last time I'm going to be stuck.
-Whoever named Purge Hose and Hose-Purge was a Genius. Probably the snowflake that snowballed into this mystery.
-Thanks Thermo for getting me in the right direction. All hail Thermo!
SOLVED:
Code:
[Intake Manifold]---*HOSE-PURGE*---[Purge Valve (#9)]---Purge Hose---[Cyclinder]---Plastic Tube---[Firewall].
In conclusion:
AceVentura (04-15-2023)
Received 3,923 Likes
xFyght, the hose that you are talking about is what connects the intake manifold to the purge valve for the emissions control system to draw a slight vacuum on the gas tank I believe. Looking at Jaguarparts.com, they call it a "Vapor Hose". They won't list a part number for it, but they want $30 for the hose.
Hope this helps.
Hope this helps.
I found what you're talking about, Thermo
Close Thermo! So Close.
Based on the Valve Assembly(8), the "Vapor Hose"(10) connects at the Purge Valve (9) at the bottom, shorter port.
I need the hose that connects to the Purge Valve(9) at the top port and at the top of the manifold. Which isn't in the picture.
But Thank you very much on letting me know what the system it's apart of.
EMISSION SYSTEM!
EMISSION SYSTEM!
xFyght, then tell them you need the Purge Valve Hose. They should be able to figure it out. Tell them that you don't need the vapor hose, you need the purge valve hose (ie, the one that goes between the intake and the purge valve. If they can't find it based on that, then you need to move on to a different dealership. If you call up JPLV, they should be able to get you the hose at a good price (including shipping).
xFyght (08-07-2013)
Part Number & Name: C2S16505 and Hose-Purge
C2S16505 HOSE-PURGE
Price Verified by 3 Dealers in the DC and JPLV
JPLV
MSRP Price: $133.75
Price Before Shipping from JPLV: $100.31
Price With Shipping: $115.26 - $155.48
Dealer's Prices in my area $121-164
You better hope you didn't break the little rubber gasket because it doesn't come with it.
When I googled the part number, Not a single picture showed up.
Dealer wont show or email picture. if anyone is kind enough, could you get a copy or verify if its the real deal.
I had the dealer order the part and I will get it Friday. Will confirm when I've received it.
JPLV
MSRP Price: $133.75
clubairth1
29
05-10-2024 12:57 PM
