X-Type Workshop Manual - Caution
Yes, just a word of caution if you should come across websites offering thesedownloadable electronic workshop manuals. I've fell for this twice now only tofind upon opening the downloaded file a copy ofthe Jaguar (JTIS). This particular website charged£10 for this downloadand the upsell suggested they were offeringa completeDIY workshop manual. Although I believe Haynes don't do a workshop manual for the X yet, I was expecting something similar. I have emailed the supplier but received no response to date - Not impressed...
winocco (07-12-2013)
Received 9,009 Likes
Like I say, for those that remember the old Haynes manuals even the most reluctant DIYer could have a go atmany of the repairs etc following explicit instructions, excellent pictures and practical tips. On the other hand I think the JTIS is best suited as a reference for perhaps Jaguar trained mechanics. If for example a part has to be removed in order to gain access to a faulty part, the information is very limited and does not explain in any great detail. For example check out the section on replacing brake rotors / pads! (You may, of course, disagree)...
You are right Kenzed the JTIS is for Jag techs at the dealerships, etc.
I contacted Haynes shortly after getting my X Type and if I rememberthey said they have no plans to introduce a manual for the X type as they have to wait until it is a certain age before Jaguar will allow them to bring one out.
Guest
Posts: n/a
here is what is on my JTIS CD for just the front brake pads. I cant imagine a more thorough instruction, and there are 6 pictures to go along with it. I am curious if you have a different disc than I do.
FROM JTIS
Brake Pads:
Remove the wheel and tire. For additional information, refer to .
Pivot the brake caliper upwards.Remove and discard the brake caliper lower retaining bolt.
Remove the brake pads.
If the piston is pushed back into the housing, brake fluid will be forced into the fluid reservoir.
Make sure that the brake disc faces are clean before installation.
Push the piston into the housing.
Install the brake pads.
Pivot the brake caliper downwards.
Install a new brake caliper lower retaining bolt.Tighten to 30 Nm.
Install the wheel. For additional information, refer to .
FROM JTIS
Brake Pads:
kiyana (07-27-2015)
BuckMR2,
Thanks for your support - You've summed it all up...
Very often and particularly with cars these days, it is not always obvious how to go about gaining access to a specific part and it's not until after the job that you realise you could have done things a lot easier with a little help!
The Haines provided anyone who wished to 'have a go' with the confidence to get the spanners out and save a few bucks/quid (£'s).
I vote Haines make a X-Type manual as soon as possible so we can all get back to some old fashioned values, that is...pulling things apart on a Sunday morning while the wife cooks the dinner![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Kenzed..
Kenzed..
