Xenon Headlight Flickering, then goes out
As I don't typically drive the X-Type at night (it's my commuter, have another car) it hasn't been a huge problem but I'd like to get it fixed (without a giant expense).
When I start the car, both the driver and passenger headlights work fine, and auto-level as they should. Maybe 5 minutes into my drive, the passenger light will start to flicker and a couple minutes after that, it will go out completely.
The strange thing is that after leaving it parked for a while, when I goto start the car again, both lights are working and the process starts all over. This has been going on for over a month.
Does anybody have any suggestions on what I could replace or check first?
Thanks.
Thanks.
There are four possible causes, any one of which or combination of these can cause a flicker and/or the light to flicker then go out:
1. Bulb going bad
2. Ballast starting to fail
3. Low voltage to the headlamp assembly (not likely the battery if only one side flickers)
4. Bad ground to that side.
Eash of these has to be checked as you'll spend a lot of money here if you just "shotgun" replace parts.
1. Bulb going bad
I found out how to repair the ballast.
Here's how to
https://magixians.wordpress.com/2017...allast-repair/
Here's how to
goges
10-05-2015 05:53 PM
Fletch44
09-28-2015 03:21 PM
